HELP! Blue Screens
Coengoofy
Hello everybody,
Last week i got an 'bitcoin miner cpu' trojan horse at my laptop. Happily i erased it. The pc looked fine until i get every now en then a blue screen with the following codes:
DRIVER_IRQL_NOT_LESS_OR_EQUAL (igdkmd64.sys)
CRITICAL_STRUCTURE_CORRUPTION
Also my task manager says my disk usage is 100%. Most of the time by system.
I know how to reinstall windows but i rather fix the problem. I hope its not some hardware that broke.
I already did research after the problem. it is a well known problem but there are so many different things dat cause this crash. Some guy told me to delete the nvidia graphiccard en reinstall the driver. now i can't get it back! I dont have the knowledge so i hope you guys can help me out!
Specs:
Intel Core i7-3632QM 2.2GHz with turboboost up to 3.2 GHz
6GB DDR3 Memory
NVIDIA GeForce 710m (2gb VRAM)
Greetz Coen
    Windows
    Acer V3-571g
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Gigabyte B150-HD3P-CF
    16GB DDR4 2133 Crucial Ballistix Sport LT
    MSI GeForce GTX 1060 GAMING X 6G
    Built-in
    Liyama ProLite XB2483HSU-B2
    Crucial MX200 500GB & Toshiba DT01ACA300 3TB
    Corsair RM550x
    Fractal Design Define S
    Cooler Master TX3 i
    Func KB-460 (MX Red)
    Corsair Gaming M65 RGB
    Bitdefender Total Security 2017 + MBAM Pro + MBAE Pro
    Creative Sound Blaster Tactic3D Rage V2 headset
with spyhuter 4 and malwarebytes
after that checked with avast.
but i already reinstalled windows. no problems anymore and its running fast again. Is faster then working 3 days on debugging.
thanks!
    Windows
    Acer V3-571g
If you reinstalled Windows and are having no more problems, please mark this thread as solved :)
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
