Solved CLOCK_WATCHDOG_TIMEOUT and DPC_WATCHDOG_VIOLATION issues
NathanD212
I keep getting blue screen and the same error is caused by ntoskrnl.exe AND sometimes hal.dll
i dont even have to open or run anything it will just crash after a while it evne crashed tryingto run the dm-info executable listed in the how to for BSOD
error code is usually either: 0x00000101 OR 0x00000133
    AMD Ryzen 7 1700x
    ASRock AB350 Gaming K4
    2 - 8 GB PC4-19200 DDR4 SDRAM Kingston KHX2400C15/8G
    Sapphire RX 480 Nitro+ OC
    Samsung SSD 850 EVO 1TB
    WDC WD2003FZEX-00SRLA0
    COMODO
here is system info
  • DESKTOP-16_01_2018_143647_06.zip
    AMD Ryzen 7 1700x
    COMODO
Hi NathanD212,
Welcome to 8forums :)
Run chkdsk /r on both your partitions.
2018-01-16T12:27:42.669		Volume OS (\Device\HarddiskVolumeShadowCopy5) needs to be taken offline for a short time to perform a Spot Fix.  Please run "CHKDSK /SPOTFIX" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
2018-01-16T12:20:12.674		Volume C: (\Device\HarddiskVolume1) requires an Online Scan.  An Online Scan will automatically run as part of the next scheduled maintenance task.  Alternatively you may run "CHKDSK /SCAN" locally via the command line, or run "REPAIR-VOLUME <drive:> -SCAN" locally or remotely via PowerShell.
2018-01-16T12:20:12.674		Volume C: (\Device\HarddiskVolume1) needs to be taken offline for a short time to perform a Spot Fix.  Please run "CHKDSK /SPOTFIX" locally via the command line, or run "REPAIR-VOLUME <drive:>" locally or remotely via PowerShell.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Gigabyte B150-HD3P-CF
    16GB DDR4 2133 Crucial Ballistix Sport LT
    MSI GeForce GTX 1060 GAMING X 6G
    Built-in
    Liyama ProLite XB2483HSU-B2
    Crucial MX200 500GB & Toshiba DT01ACA300 3TB
    Corsair RM550x
    Fractal Design Define S
    Cooler Master TX3 i
    Func KB-460 (MX Red)
    Corsair Gaming M65 RGB
    Bitdefender Total Security 2017 + MBAM Pro + MBAE Pro
    Creative Sound Blaster Tactic3D Rage V2 headset
but i dont have any nvidia drivers as far as i know
    AMD Ryzen 7 1700x
    COMODO
Hi NathanD212,
if i run chkdsk /r will it check both partitions at once?
    AMD Ryzen 7 1700x
    COMODO
I have been having this issue, along with other people recently. I think it may be the recent windows update. This guy did a system restore before the update and it seems to be working. I did a system restore and I will see if it works. In my dump file it appeared to be an issue with nvidia drivers.
just started getting dpc watchdog violation crashes : windows8
acording to that reddit post it is potentially aused by the spectre/meltdown update microsoft pushed, if i am running ryzen 7 and b350 chipset will that cause issues, i do not want to try and remove updates before i at least get someone elses opinion.
    AMD Ryzen 7 1700x
    COMODO
Hi NathanD212,
i ran chkdsk /r and it seemed to complete fine without errors i have reuploaded the dm-machine.zip could you please check if nothing else obvious is potentially the issue, thank you.
  • DESKTOP-17_01_2018__05532_33.zip
    AMD Ryzen 7 1700x
    COMODO
    AMD Ryzen 7 1700x
    COMODO
well it crashed again :(
here is latest zip file
  • DESKTOP-17_01_2018__14942_07.zip
    AMD Ryzen 7 1700x
    COMODO
i just uninstalled
2018-01 Security Monthly Quality Rollup for Windows 8.1 for x64-based Systems (KB4056895)
2018-01 Security Update for Adobe Flash Player for Windows 8.1 for x64-based Systems (KB4056887)
and patch kb4073576
now lets see what happens...
    AMD Ryzen 7 1700x
    COMODO
uninstalling updates seems to have fixed the issues for now :)
    AMD Ryzen 7 1700x
    COMODO
i believe that it is due to a broken MS update, after uninstalling KB4056895 i was able to run multiple firefox tabs and 2 steam games (quite recent releases) at the same time for at least 2-3 hours without issues. i also found and will link the exact comment from a bleepingcomputer thread that shows someone else was able to resolve this by doing the same:
CLOCK_WATCHDOG_TIMEOUT BSOD Problems - Windows Crashes, BSOD, and Hangs Help and Support
    AMD Ryzen 7 1700x
    COMODO
i dont know if i should mark the thread as 'solved' because i dont believe that what i did is a true fix for the issues potentially caused by MS update KB4056895.
should i keep this thread the way it is until MS releases a proper update/patch that covers spectre/meltdown without horrible BSOD or should i say that its solved and simply tell people to uninstall that update for now?
    AMD Ryzen 7 1700x
    COMODO
yup that seems to be the culprit, but then microsoft has also released a patch KB4073576:
"An update is available to fix the following issue that occurs after you install January 3, 2018—KB4056898 (Security-only update) or January 8, 2018—KB4056895 (Monthly Rollup): AMD devices fall into an unbootable state."
but it doesnt do anything for some reason, so i just unistalled both that KB4073576 and KB4056895 and clicked hide update
    AMD Ryzen 7 1700x
    COMODO
You will want to install those updates, if you don't, you could compromise your system by accidentally visiting a wrong website.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
